This is an odd one...
My throttle lever rubs on the intake manifold bolt. It did this back in 88 when I first "restored" the car and my quick fix was to just bend the lever so that it clears. If I remember it right, the lever can't move past the bolt once the carb is bolted down. Now that it's getting a proper restoration I want to fix this interferance problem and all I can think of is that the original carb gasket was thicker than what came in my carb kit.
Here is the problem.
![](http://i40.photobucket.com/albums/e232/Lintmann/P1010142-1.jpg)
Here is the gasket and heat shield.
![](http://i40.photobucket.com/albums/e232/Lintmann/P1010143-1.jpg)
Does the gasket look like it might be the problem? I can't figure out why else the lever would be hitting the bolt?
![Confused](https://www.forums.ncrs.org/core/images/smilies/confused.png)
