If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
It all depends upon the particular component you're concerned about. Some 'early components' became 'late components' or 'mid-year components' earlier than others. Wheeeeeew Perhaps if you describe your what you're concerned about, we could help better. Regards, Kent
Kent 1967 327/300 Convert. w/ Air - Duntoved in 1994 1969 427/435 Coupe - 1 previous owner 2006 Coupe - Driver & Fun Car !!! NCM Founder - Member #718
My car has a nov 5 68 build date .Judging manual states early 69 smog pump had vents late cars non vented.I have seen an original owner car dec 68 427/435 car with a vent and i have seen earlier cars with no vent.My car is a 427/435 what is the correct pump.
Anthony, we generally look for non vented pumps on '69's, with the exception of L/88 cars which were vented.
I agree. I've never seen a known-original 1969, except L-88/ZL-1, that had a pump with a pressure relief valve ("vent"). While one of the 1969 big block AIM drawings does show a "plug" (which is actually the part that sets the relief pressure of the 68-style pump), I believe the "plug" is an anachronism resulting from a 68 drawing being used. Beyond that, the 1969 big block AIM page shows that the big block uses the "production" pump. The "production" pump means the same pump as used for the base engine which is exactly the pump that I believe all 1969 Corvettes except L-88/ZL-1 originally used.
Also, keep in mind that the pump usually supplied when a rebuilt pump is obtained for a 1969 is the pump with the integral relief valve. Also, the pump that GM supplied in SERVICE for many years (but not original SERVICE) was a pump with the integral relief valve.
The pump with the integral relief valve will work perfectly for any 1969 Corvette, though. However, the 1969 style pump without relief valve should not be used for any 1968 model or any 1969 L-88/ZL-1.
