If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Thought you owners of Canadian cars might enjoy this.
Jim
Too bad I don't have a photocopy of the GM Canada microfiche sheet on which that particular car appears, to show the original format of the documentation that was gathered back then, and from which Zapora now creates the new "sticker" under GM Canada letterhead.
The closest I have is the Canadian-delivered Corvettes from 9S721497 to 9S722222, a total of 20 in that VIN range.
Same GM of Canada oil change recommendation sticker as the one on my Canadian-delivered unrestored '69 Camaro Z/28; it was the only part that differentiated a Canada-vs-U.S. '69 Camaro.
