If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
What is the main difference between the 68 and 69 door weatherstrip? I'm mostly concerned with the aft portion where the rubber touches the door glass.
