My 2003 Convertible is at the shop, I took it in to have a "Check Engine Light" issue diagnosed. The other problem I had was a "Service Column Lock" fault displayed when I started the car. After starting the car, I would hit the reset button and the erorr message never appeared again till the car was shut off.
After 3 hours at the dealership, the answer was "there is a short somewhere in the electronics" and we can't find it yet. Work to resume on Monday.
I had the recall notice on the column lock back in 2004, and the car was serviced under warranty.
I am writing to see if anyone else has had these symptoms and knows what the problem was. Any help will be appreciated.
Thank you,
George
Thank you,
George
