1969 L71 Intake Manifold Overspray - NCRS Discussion Boards
  • Kent K.
    • November 30, 1982
    • 1139
    For those interested, I've finally photographed my intake manifold which was removed from the engine in 1971 by the original owner and stored. Obviously, some of the overspray was worn off by handeling / abrasion during its many years of storage. These photos depict the condition of the manifold, carbs, linkage, etc. as received. Nothing on this assembly has been changed or cleaned since I bought the car.
    Additional photos besides the one below:
    http://i19.photobucket.com/albums/b157/2k234/69%20Corvette/012A.jpg
    http://i19.photobucket.com/albums/b157/2k234/69%20Corvette/009A.jpg
    http://i19.photobucket.com/albums/b157/2k234/69%20Corvette/008A.jpg
    http://i19.photobucket.com/albums/b157/2k234/69%20Corvette/005A.jpg
    http://i19.photobucket.com/albums/b157/2k234/69%20Corvette/003A.jpg
    http://i19.photobucket.com/albums/b157/2k234/69%20Corvette/007A.jpg
    http://i19.photobucket.com/albums/b157/2k234/69%20Corvette/013A.jpg
    In order to see these photos, you'll have to copy and paste each entire URL line. Why it dosen't highlight and underline the whole URL is anyone's guess.
    It's really strange how the "overspray" was built up on the boss and allowed to run as shown in picture 003A, 007A and 013A. I believe overspray on the sides has worn off by handeling and was, probably, more uniform matching bits remaining in pics 001A and 005A.
    Hope this helps both restorers and judges to realize there are many variations and coverages of overspray on 1969 L71 aluminum intake manifolds. This is specific information and is not intended to represent more than what is on this manifold.
    Kent
    Kent
    NCM Founder - Member #718
  • Greg L.
    • February 28, 2006
    • 2291
    Re: 1969 L71 Intake Manifold Overspray
    Ah Kent that was perfect timing!
    I'm in the process of re-doing my intake overspray and actually went so far as to make a fiberglass "mask" to mimic the original vacuum formed mask that was used.
    http://i40.photobucket.com/albums/e232/Lintmann/P1010084-1.jpg
    http://i40.photobucket.com/albums/e232/Lintmann/P1010086-1.jpg
    ...yes I may have too much time on my hands!
    Your pics will help A LOT in modifying my mask a tiny little bit before I re-spray the intake.
    Thanks so much for posting the pics.
    Greg
    • Greg L.
      • February 28, 2006
      • 2291
      Greg
      • John C.
        • December 31, 2004
        • 616
        Kent
        Great pictures. Your overspray pattern looks very close to what I have on my 68 435hp. You have a little bit more left on the edges and I'm missing the big blob and run on the boss but that is the only real difference.
        John
        • John C.
          • December 31, 2004
          • 616
          Kent
          John
          • Michael Ketterer
            Kent
            Do you still have the air cleaner? if so the base could you post a pick of the bottom? Also the bolts holding the base, what is your letters marks ect... on the heads of the two bolts.
            Thanks Michael
            ps good to see you up and feeling better!
            • Michael Ketterer
              Kent
              Thanks Michael
              • Kent K.
                • November 30, 1982
                • 1139
                Mike,
                If you're asking about the two bolts that secure carb basr to the manifold along with the threaded studs, they are 'R' with three lines (grade 5). If you're asking about something else, please explain.
                I'll try to photo the air cleaner instructions. Anything else?
                Kent
                Kent
                • Kent K.
                  • November 30, 1982
                  • 1139
                  Mike,
                  Kent
                  Kent
                  • Kent K.
                    • November 30, 1982
                    • 1139
                    Addendum
                    I failed to mention that the bolts holding the carb bases are finished with black phosphate.
                    Kent
                    Kent
                    • Kent K.
                      • November 30, 1982
                      • 1139
                      Addendum
                      Kent
                      Kent
                      • Michael Ketterer
                        Kent
                        That's the answer to my question.
                        Thank you very much.
                        Michael
                        • Michael Ketterer
                          Kent
                          Michael
