1967 power booster hose orientation - NCRS Discussion Boards
  • Keith B.
    • December 1, 1991
    • 397
    I am looking for the configuration of the power brake hose on a 1967 big block. I have the hose going parallel to the firewall straight across into the power booster valve. Does it cut across the front of the distributor and behind the carburetor? I am assuming that the vacuum hose adapter that sits on the manifold is pointing directly to the fender of the car on the left side. That would make it go straight. Could somebody please post a picture just to make sure that I am placing it correctly.
    Keith Burmeister
  • Leif A.
    • August 31, 1997
    • 3624
    Re: 1967 power booster hose orientation
    Keith,
    Picture of my '67 L79...BB is routed the same. You want to be sure to stay clear of the accelerator linkage.
    Leif
    • Keith B.
      • December 1, 1991
      • 397
      This does not show the orientation of the vacuum hose fitting on the manifold. Can someone help on that please
      Keith Burmeister
      • Owen L.
        • September 30, 1991
        • 856
        Looks like it's straight off the manifold fitting and over the accelerator rod. (J50, A3)
        • Leif A.
          • August 31, 1997
          • 3624
          How about this...
          Leif
          • Tim G.
            • March 1, 1990
            • 1367
            • Tim G.
              • March 1, 1990
              • 1367
              Pictures sent.
