73 Hood Vent acorn nuts
  • David C.
    • January 23, 2024
    • 35
    Does anyone have a close-up photo of the black acorn nuts that attach the hood vent to the hood? My 73 was repainted at one time by a prior owner, and the acorn nuts were replaced with speed nuts.
    73 Coupe, L-48, auto, Body Build Date: 31 May 1973
    Member - Southern Nevada Chapter NCRS
  • David K.
    • October 1, 1979
    • 231
    Re: 73 Hood Vent acorn nuts
    They are on page 77 of the TIMJG
    • David C.
      • January 23, 2024
      • 35
      So anything that looks vaguely acornish from a distance.
      • David K.
        • October 1, 1979
        • 231
        # 9420621 is the number from the AIM.
        Check Zip's or one of the other part vendors for these. I'm sure they have them for you.
        • Jimmy P.
          • June 25, 2014
          • 1693
          Here ya go David,
          Originals from a 73 & 74 hood!
          Exactly what you'll need for your '73
          Jimmy
          1973 Convertible
          L48,M20,N40
          Mille Miglia Red/Oxblood
          • David C.
            • January 23, 2024
            • 35
            Great photos, Jimmy. That's just what I needed to see. A few thousand more pixels makes a world of difference. Thank you.
            • Gary B.
              • February 1, 1997
              • 6851
              This new old stock  molding and emblem retaining nut was manufactured by General Motors for use on the following models: Grill emblem Nut  1.303 Chevrolet 1975  Monte Carlo, Front Fender Molding and Script – 8.132  Oldsmobile 1972 Cutlass – script and rear molding, Front Floor Console Nut Chevrolet  1989 – 1993 Corvette, Seat Back Lock […]
              Gary
              • David C.
                • January 23, 2024
                • 35
                Those speed nuts are what is installed in my 73. According to the TIMJG those are not the correct type of nut. I'm assuming mine are replacements.
                  • 11535
                  Originally posted by Gary Beaupre (28818)
                  Here’s a company that claims to have some NOS examples of GM 9420621.
                  Gary
                  Ironically, GM changed the configuration of this part number completely.
                  What started life as the acorn nuts ended up life as the speed nuts.
                  Same part number.
                  • Gary B.
                    • February 1, 1997
                    • 6851
                    • John S.
                      • June 16, 2015
                      • 504
                      1973 L82 M21 4 Speed, very original and well documented driver/survivor
                      NW Chapter Member, 2016 Bend Regional Top Flight
                      73/74 TIM&JG 3rd Edition Revision Team Member
                      • Russ S.
                        • May 1, 1982
                        • 2158
                        Last I knew they weren't available.
                        • Gary B.
                          • February 1, 1997
                          • 6851
                          Rich Pasqualone or David Sokolowski might have some restored and/or used originals.
                          Gary
                          • David C.
                            • January 23, 2024
                            • 35
                            Thanks, John. Great pics. I'll have to fake it if I can't find some junk yard nuts. Hmmm, I might be able to 3D print fake ones out of resin.
                            • Gary B.
                              • February 1, 1997
                              • 6851
                              David,
                              What about these: https://corvetteparts.com/item/hood-...-set-1973-1976
                              Gary
