Does anyone have a close-up photo of the black acorn nuts that attach the hood vent to the hood? My 73 was repainted at one time by a prior owner, and the acorn nuts were replaced with speed nuts.
73 Hood Vent acorn nuts
Re: 73 Hood Vent acorn nuts
Here ya go David,
Originals from a 73 & 74 hood!
Exactly what you'll need for your '73Jimmy
1973 Convertible
L48,M20,N40
Mille Miglia Red/Oxblood
- Top
Great photos, Jimmy. That's just what I needed to see. A few thousand more pixels makes a world of difference. Thank you.73 Coupe, L-48, auto, Body Build Date: 31 May 1973
Member - Southern Nevada Chapter NCRS- Top
This new old stock molding and emblem retaining nut was manufactured by General Motors for use on the following models: Grill emblem Nut 1.303 Chevrolet 1975 Monte Carlo, Front Fender Molding and Script – 8.132 Oldsmobile 1972 Cutlass – script and rear molding, Front Floor Console Nut Chevrolet 1989 – 1993 Corvette, Seat Back Lock […]
Gary- Top
Those speed nuts are what is installed in my 73. According to the TIMJG those are not the correct type of nut. I'm assuming mine are replacements.73 Coupe, L-48, auto, Body Build Date: 31 May 1973
Here’s a company that claims to have some NOS examples of GM 9420621.
Gary
What started life as the acorn nuts ended up life as the speed nuts.
Same part number.Vice-Chairman (West), Michigan Chapter NCRS
1973 L82 M21 4 Speed, very original and well documented driver/survivor
NW Chapter Member, 2016 Bend Regional Top Flight
73/74 TIM&JG 3rd Edition Revision Team Member- Top
Thanks, John. Great pics. I'll have to fake it if I can't find some junk yard nuts. Hmmm, I might be able to 3D print fake ones out of resin.73 Coupe, L-48, auto, Body Build Date: 31 May 1973
David,
What about these: https://corvetteparts.com/item/hood-...-set-1973-1976
Gary- Top
