There is a ton of information with some conflicting information. I have what it appears to be a 71-72 solenoid.
It has two tabs and vacuum lines to it. It is not working . I have one tan wire that receives 12V when the ignition is on but the solenoid does not power up as connected. Looking on line shows solenoids for 71-74 with a single lead. Can someone tell me if this is indeed the correct solenoid or do I need to order one with the single tab? What is the deal with the vacuum. Now that I have proper timing, I need to get this working to prevent dieseling.
