1957 Throttle Return Springs - NCRS Discussion Boards
  • John P.
    • January 1, 2006
    • 162
    Hello, is it possible that someone can supply me a photo of the correct primary and secondary throttle return spring installation on a 1957 fuel injection unit? I am working on a friend's car and the previous owner installed universal springs, He ordered the correct springs and bracket from one of the suppliers and I would like to be sure of the correct installation. As always, thank you so much for all the help, John
  • Gary C.
    Administrator
    • October 1, 1982
    • 17697
    Re: 1957 Throttle Return Springs
    John, refer to AIM RPO 579 sheet 2
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • John P.
      • January 1, 2006
      • 162
      Hello Gary, thank you for the input. I saw this in the AIM, however it does not show the secondary spring and bracket that attaches to one of the ignition coil mount bracket bolts. The AIM shows the primary spring but not the secondary spring. I will install the bracket when he gets the parts and check for mount points on the linkage. Thanks again for your time, John
      • Gary C.
        Administrator
        • October 1, 1982
        • 17697
        suggest you send an email to the NCRS FI rep https://www.ncrs.org/contact/index.php
        NCRS Texas Chapter
        • Jim L.
          • September 30, 1979
          • 1808
          While dual return springs are a Really Good Idea, and as a practical matter I recommend them, to the best of my knowledge only a single return spring was used in '57.
          Here is how dual springs would be implemented on '62 and older FI installations:
          • John P.
            • January 1, 2006
            • 162
            Hello Jim, once again thank you so much. This picture is worth a thousand words. Thanks, John
            • Frank C.
              • March 1, 1977
              • 67
              Thanks also from Frank Condron. I bought my car in1973 and now I know how it's supposed to be!
