61 Side Trim T Studs - NCRS Discussion Boards
  • Mark S.
    • July 31, 1983
    • 660
    IMG_4272.jpgIs there a technique of installing these T studs on the side trim of my 61? I do not remember having trouble with these on my 56. Do people use dum dum or a needle nose to help set these studs in place. Maybe the problem is my old hands. Thanks!
  • Mike M.
    • May 31, 1974
    • 8389
    Re: 61 Side Trim T Studs
    I use 3-M black caulking strips cut to about 1/4" per the t-studs. mike
    • Mark S.
      • July 31, 1983
      • 660
      Thanks Mike! That is very helpful!
      • David Z.
        • April 1, 2002
        • 181
        Here is some more info regarding the side molding clips with a tip from John Hinckley.
        Dave Z
        Dave Zuberer
        • Mark S.
          • July 31, 1983
          • 660
          Thanks! I did use the 3M strip caulk. I also used a marker to identify where the clips would go. I was able to wipe off the marker marks after installation. I used NOS clips, and I did snap one, so do not over tighten them.
          • Steven B.
            • June 30, 1982
            • 3990
            When I removed my Dec 56 originally installed pieces in summer of 65 they had black dum dum holding them in position.
            • Mark S.
              • July 31, 1983
              • 660
              My 56 "4200" did not have dum dum securing the original clips.
