1966 427/390 one low cylinder - NCRS Discussion Boards
  • John B.
    • April 20, 2021
    • 111
    Hello all, i just did a compression test on my 427/390 stock. cylider 1 was 160, 5 was 145, all the rest were 180. Decided to do a leak down on 1,3,5. Cyl 1 was 8% rings, Cyl 3 8% rings and Cyl 5 was 6% rings. I was thinking 5 would have been worse with such a low compression. Does any one have any suggestions on what might be going on? The car sat for 18 years, i have ran it for 5 hours since.
    Mike
  • Chris H.
    • April 1, 2000
    • 837
    Re: 1966 427/390 one low cylinder
    Mike does the motor use oil? Does it smoke? How do the plugs look? How does it run?
    • John B.
      • April 20, 2021
      • 111
      Chris, if it uses oil it is very little. No smoke. The plugs showed a rich burn. Runs and sounds great.
      We hooked up the sun machine. We killed each cylinder. All had rpm drop except 5.
      Mike
      • Danny P.
        • June 30, 2002
        • 341
        You have fresh oil if not do a oil change and filter and go for a long steady ride without stopping its been sitting for 18 years you may have a sticky ring and valve seat on # 5 cyl i would try that before taken anything apart then recheck Cyl. 5
        • Mark E.
          • April 1, 1993
          • 4517
          Agreed. If it runs okay, put some time on it and then recheck.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • John B.
            • April 20, 2021
            • 111
            Thanks Danny and Mark. I will do that.
            Mike
