Tach shaft too short - NCRS Discussion Boards
  • James F.
    • March 1, 1997
    • 44
    On my 61, generator on passenger side, 270 HP. The shaft inside the cable is too short to go into the generator tach drive. I'm looking for a third order, Paragon and now Corvette Central the same problem. Even when I pull on it, it still doesn't get anywhere near the brass part. There is a collar on the guage side that prevents the shaft from coming out of the guage.
  • Tim S.
    • May 31, 1990
    • 706
    Re: Tach shaft too short
    I had the same problem on my 62. I ended up getting a parts store cable insert, and made a new cable to go into my NEW tach cable (from Zip). The only other option you would have, is to have a new cable made. I recently had a referral passed on to me, as a friend of mine ran into the same problem as well.
    Tim
    • Leif A.
      • August 31, 1997
      • 3631
      Give these folks a call...they'll fix you right up.
      Speedometer Cables Service Since 1932! Speedometer Cables USA is a 3rd generation Colorado owned company in Denver, Colorado.
      Leif
