1963 Power Brakes locking up - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1309
    I'm now putting my 63 on the road and doing "shake down" cruises. I've had it out about 6 times and the last two times, after about an hour's ride, I pull into my driveway/garage and the brakes lock up slightly. I can still move the car, but you can tell the brakes are on. It did it this morning. When it did it the time before, I let the car sit and afterwards, the brakes are fine. Again, it happened this morning after about an hour's ride in 75-degree weather.
    Is it the check valve on the booster??? OR is it that small hole in the M/C that could be blocked as mentioned in another post on the TDR?
    Andy Cannizzo rebuilt this unit and I've always had great luck with Andy's boosters (both of them that I bought from him)
    Thoughts??
  • Leif A.
    • August 31, 1997
    • 3650
    Re: 1963 Power Brakes locking up
    Gerald,
    Are you still running the stock drum brakes? If so, are they properly adjusted? If they're adjusted a bit too tight when cold, when they heat up they expand and could be causing the problem. Just a thought.
    Leif
    • Peter H.
      • April 1, 1980
      • 229
      Hello Gerald. It Sounds Like A Collapsed Brake Hose. After Sitting For A While The Back Pressure Is Released. Someone More Experienced Can Chime In. Just My Two Cents And I Hope It Helps. Peter Hannigan (3522) 🇨🇦
      • Gerald C.
        • June 30, 1987
        • 1309
        Leif,
        Yes I'm still running stock drum brakes. I believe they are adjusted properly since this just happened and hasn't happened previously.
        • Gerald C.
          • June 30, 1987
          • 1309
          Peter,
          I replaced all the brake hoses recently during my restoration. It could be that these are defective and I might replace all of them! Before I do that, I think it best that I see a few more replies. You're idea has real merit!! Thanks
          • David M.
            • September 30, 2004
            • 533
            Agreed with the collapsed hose theory.
            How old are the 4 flex hoses? They are consumable and should be replaced every so often time & mileage dependant.
            Verify the E-Brake is 100% released.
            Verify shoe drag is even on all 4 wheels.
            I've witnessed bad new hoses where the person crimping it didn't do it properly and crimped a chunk of the hose on the inside diameter. It acted like a one-way check valve.
            If it is a collapsed/blocked hose, to locate which hose is the culprit get the car up on jack stands or on a 2-post lift.
            Stand on the brake pedal a few times and immediately try to rotate each tire. The one hanging up will have the bad hose.
            To verify it have a bleeder wrench at your fingertips. Repeat this procedure and crack the locked-up wheels bleeder. It should shoot brake fluid and release the wheel to allow free rotation.
            • Gerald C.
              • June 30, 1987
              • 1309
              Thanks David. One other thing I just remembered about the brakes.....when the car gets warm after several miles of driving, the brakes get VERY sensitive and grab very quickly. Could this also be a result of a bad hose?
              It looks like I should replace all 4 hoses, just to be on the safe side!
              • David M.
                • 533
                Is the brake system all new or not? I see the master booster assembly is new. New means nothing today.
                Best to troubleshoot vs throwing parts at it. Find known USA-made parts.
                Pull the drums and inspect for loose hardware, leaking cylinders, glazed drum surfaces and if the primary & secondary shoes are in the right locations.
                Sticking sensitive grabby brakes can be a few different things.
                1. Adjustment is wrong, shoes are too far out.
                2. Contaminated shoes
                3. Primary & secondary shoes reversed
                4. Inferior shoe composition
                5. Wrong shoes all together
                6. Hardware is worn out
                7. Booster is leaking vacuum. Turn engine off. Wait a few mins and remove the check valve. Should hold vacuum for a while.
                8. Contaminated fluid
                9. Glased drum surface.
                10. OR You have superhuman leg muscles.
                Also, do a complete power bleed of the system to flush out any chunks.
                DOT 3 & 4 Brake fluid is hydrophilic and should be changed every 3-5 years. Hoses every 10 or so.
                Report back when you find the problem.
                • Gerald C.
                  • June 30, 1987
                  • 1309
                  Dave,
                  Brake shoes are new
                  I've had the hoses for a while and then put them on. I do not know how old they were, but they were new "at the time"
                  I don't see any leakage around the wheels at all.
                  The brakes worked fine for a while until these incidents occurred
                  The shoes are installed properly
                  I will pull the shoes and see what's going on
                  I'll try #7 later today
                  Fluid is brand new Dot #3
                  I'll check the drum surfaces
                  I'm old, I no longer have superhuman leg muscles!
                  I'll keep you posted.
                  Thanks!
                  • Owen L.
                    • September 30, 1991
                    • 891
                    How full is the master? I believe it needs some headroom for the brake fluid to expand back into as the fluid heats up at each wheel.
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11359
                      If the booster push rod to the master cylinder is too long it could cause a lockup condition. This happens because the inner MC seal blocks the return port. The condition is exacerbated with heat.
                      It's tricky to measure the rod clearance, but a simple method to verify if it's too long is to space out the master cylinder to the booster by adding flat washer(s) between them. A thick gasket is another method.
                      Another possibility is that the emergency brake cables are hanging up and not releasing completely.
                      Rich
                      • Harry S.
                        • July 31, 2002
                        • 5342
                        Because the booster rod is adjustable on a 63. I used this tool for setting the proper depth on the rod.
                        Amazon.com: (Upgraded) Brake Adjustment Tool, Brake Booster Rod Adjustment Tool, Brake booster with master cylinder,Pushrod Power For Adjustable Braking Distance of Brake Pedal(N48 Magnetic CNC Aluminum) : Automotive
                        • Gerald C.
                          • June 30, 1987
                          • 1309
                          Master cylinder is filled to specs.
                          • Gerald C.
                            • June 30, 1987
                            • 1309
                            Rich,
                            The brakes worked fine the first few times I took the car out and then this situation occurred. The Parking Brake is adjusted to spec's and doesn't come into play.
                            • Gerald C.
                              • June 30, 1987
                              • 1309
                              Since this just started to happen, I'm going to check the brake adjustments on the wheels first. The booster rod you refer to is the rod that comes out of the booster and onto the brake pedal? And not the one that goes into the master cylinder, correct?
