C1 high torque starter - NCRS Discussion Boards
  • E B.
    • March 1, 1978
    • 126
    My 62 FI seems slow to turn over/start. Battery high amp. Would a high torque started help with issue ? Ed
  • David H.
    • June 30, 2001
    • 1559
    Re: C1 high torque starter
    Ed
    Engine hot? Or doesn't matter?
    May be better to sort out exactly what's at issue - vs a band-aid approach (high torque starter).
    Last rebuild on your current starter?
    Dave
    • Jim L.
      • September 30, 1979
      • 1817
      Is it only the first revolution of the engine during cranking which is slow?
      Have you checked/cleaned the connections at both ends of both battery cables?
      When the engine is running at a high idle, what is the Voltage measured directly across the two battery terminals?
      David's advice is good. Don't throw parts at the problem until you understand exactly what the problem is.
      • E B.
        • March 1, 1978
        • 126
        • E B.
          • March 1, 1978
          • 126
          Jim, sometimes starting (no pun) at the source is obvious solution. Thanks, Ed
