1963 340 HP CV590 PCV Valve Whistling Dixie - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 424
    In preparation for judging in October, I installed a 590 PCV valve with new repro hose (nothing wrong with previous hose) today. It was purchased off eBay a couple months back and received in what appeared to be repro packaging. I have been using the later version 590C with no issues. After installing the 590, the idle jumped about 250RPM to 1,000. When I squirted Chemtool in the carb (needed some cleaning) and the RPM dropped, the 590 began whistling loudly at the RPM drop. I removed it and put the 590C back in and idle went back to normal with no whistling. Looks like $50 wasted unless the seller will take it back after 2 months. Just beware of repro PCV valves! I may try to do a vacuum test on it tomorrow but not expecting anything different. Other thoughts?
    Thanks in Advance,
    Fred
  • Timothy B.
    • April 30, 1983
    • 5183
    Re: 1963 340 HP CV590 PCV Valve Whistling Dixie
    Fred,
    Other than finding out the true origin of the valve and cleaning it I would say it's just another cheap reproduction part. I think the original 590 valve can be taken apart and cleaned. The GM service replace CV590 works just fine though.
    • Frederick H.
      • August 31, 1983
      • 424
      Yep - it rattles and doesn't appear to be stuck but sure affects the RPM and whistles. I was able to find an original (almost NOS/used very little) AC CV590 on eBay - will give that a try. Still trying to get choke adjusted - stays open - lots of good info here and in the shop manual on that.
      Thanks.
      • Mark E.
        • April 1, 1993
        • 4525
        Interesting mix of issues: Whistling is a symptom of a valve stuck closed, while higher idle speed is a symptom of a valve stuck open.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Frederick H.
          • August 31, 1983
          • 424
          Yep - that's what is strange. I may try it again without squirting the chemtool cleaner and re-check RPM.
          • Arland D.
            Moderator
            • July 31, 1980
            • 418
            Fred,
            Since it is a 340 hp, is it safe to assume the valve is installed at a 45 degree angle? Just checkin'
            • Frederick H.
              • August 31, 1983
              • 424
              Ah, I did not check that. At 45 degrees downward, it will put it very close to the manifold though. It's in the shop getting some things done this week - will check it out when I get it back.
              Thanks for the reminder!
              • Arland D.
                Moderator
                • July 31, 1980
                • 418
                AIM shows it 45 degrees upward putting it close to the air cleaner. FWIW here's a couple of pictures of mine.
                • Frederick H.
                  • August 31, 1983
                  • 424
                  Wow -that is one clean carb - thanks for the pics.
