If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I am wondering if anyone makes a good copper elbow for the heater hose where it goes through firewall. I ordered one from supplier and I am worried the hose will not stay on as there is no rib on each end to help hold it. Also one end on this one is squeezed thinner from the bending tool so its really loose on the hose.
