If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Can someone confirm if the 58 style heater defrost box will work in a 56. It appears like it should just won't be 100 % correct but I can't find correct one for my car.
