How long before the gas goes stale? - NCRS Discussion Boards
    • 15660
    This is an oft-asked question among vintage car owners.
    Most gasolines are blended with stabilizers and are claimed to have a "shelf life" of about a year, and I think this is conservative. Based on this and other research over the years my recommendation is that vintage cars should be driven enough every year to consume at least a full tank of fuel. So for a typical vintage Corvette that gets low to mid-teens MPG around town that's about 200-250 miles, and for cars that are stored for a few winter months the tank should be filled just prior to storage. This minimizes the vapor dome at the top of the tank, which will minimize the amount of moisture that the ethanol laced fuel might absorb from the air.
    This is especially important on cars with vented fuel systems. Since they "breathe", any moisture that's absorbed from incoming air as ambient air pressure drops drawing air into the tank and temperatures drop below the dew point, is there until it's consumed with the fuel or drops out to the bottom of the tank if the amount exceeds the co-solvent capacity of E10 gasoline.
    The current issue (May/June 2024) of Car and Driver has an interesting article on plug-in hybrids, and a sidebar at the bottom of page 63 reads as follows:
    "Won't the fuel go bad? If the thought of fuel sitting in the tank unused for an extended period has you reflexively reaching for a bottle of Sta-Bil, calm down. The Prius Prime owner's manual states that to keep the gas fresh, the engine needs to burn only half a tank per year - that's 5.3 gallons good for about 275 miles of hybrid running. If the owner fails to meet this threshold, a warning light comes on". [How clever!]
    Since all modern fuel systems are essentially "sealed" with vacuum relief valves that are not likely to open unless the car is in the eye of a hurricane or tornado, I'll stick with my original recommendation as above for vintage cars with vented fuel systems.
  • Alexander D.
    • July 9, 2015
    • 113
    Re: How long before the gas goes stale?
    Thanks Duke for this interesting and useful info!
    • John S.
      • June 15, 2015
      • 505
      Duke, very interesting. Does your recommendation change for cars running non-ethanol ??
      1973 L82 M21 4 Speed, very original and well documented driver/survivor
      NW Chapter Member, 2016 Bend Regional Top Flight
      73/74 TIM&JG 3rd Edition Revision Team Member
        • 15660
        I stick with that recommendation for either straight gasoline or E10, especially on cars with vented fuel systems. You can probably about double that and do no harm for modern cars with "sealed" fuel systems, assuming the car is stored inside and not subject to condensing humidity or extremely high temperatures for any length of time. It's a subjective call.
        In terms of water contamination, E10 acts as a co-solvent allowing a greater percentage of water to be homogeneously absorbed before saturation at which point a water-ethanol blend separates and sinks to the bottom of the tank since it's denser than the E10 blend. So in a way ethanol may actually protect the fuel system because the amount of water straight gasoline can absorb (less than one percent) is much less than E10. It's my understanding that water won't harm the fuel system until it separates, which would be water for straight gasoline and a water-ethanol mixture with E10.
        Circa 1965 my SWC had a no start condition during a Seattle cold snap when ambient temperatures remained below freezing for a few days. I suspected frozen water in the tank, and sure enough, after it warmed up the engine started. I did the normal thing...add a can of HEET to the tank, which was basically denatured alcohol that caused the water to be absorbed by the gasoline and consumed in combustion. I never experienced that problem again.
        The other way gasoline degrades is oxidation that can lead to the formation of "gum and varnish". It's very slow prrocess and, actually the colder the temperature, the slower it goes, which is why I consider additional "stabilizer" during winter storage to be unnecessary since the fuel already has stabilizer additives added by the refinery.
        For the past 30 years I've stored cars, indoors, for up to eighteen month without additional stabilizer and have never had any fuel system issues; and since I live near the coast in Southern California, ambient temperatures rarely get below 45F or over 80F.
        • Bruce M.
          Infrequent User
          • January 9, 2014
          • 27
          My 66 is garaged every summer in Florida with a dehumidifier struggling to keep the air dry. The original gas tank shows no rust after doing this for ten years and using Stabil, but the electric bill begged for an alternative. A 3-car garage with 3 overhead doors is far from airtight.
          I considered a car bag with desiccant but can't do that and raise the car on blocks in case of flooding. So, I built my own "bag" by draping plastic over the car and taping it to the epoxy painted floor. Two buckets of Damp Rid went under the car prior to taping the plastic to the floor. The desiccant claims to be effective for 6 months and each bucket absorbs about half a gallon of water.
          Every year I leave no more than 1/4 tank of gas in case a leak develops. Does anyone see a flaw in this approach to humidity control and moisture accumulation in the tank? The car cover did go on first to prevent paint damage.
          • Larry E.
            • 1673
            [QUOTE=Bruce Maser (59403);948642]
            Bruce: I have been using "Car Bags": for over 30 years with great success. I'm in Illinois with nice "unheated" no
            electricity building with concrete floor. At times I have left the vehicle (Corvettes/Camaros) in the bag for up to
            3 years WITH NO ILL EFFECT. I just do not think you can get the same effect with "taping" your bag to the floor.
            It will not give you the same sealed effect as with a solid bag. JMHO BTW> The liquid the desiccant draws is not all
            water and is very caustic when taken out. I assume you take the battery out of the car as instructed to do. I would never
            do what I do without using straight 100LL Av. Gas. as it will stay fresh/usable for SO MUCH MORE THEN THAT of
            PUMP GAS THAT IS AVAILABLE REGARDLESS IF IT HAS ETHANOL OR NOT. Thanks;Larry P.S. If you do a search
            on this board on "stale gas" you will find out that there are reports of airplanes that have not been used for 15 or more
            years AND THEN THE AV GAS IS STILL TESTED GOOD AND THE AIRPLANE STARTS!
            Larry
            LT1 in a 1LE -- One of 134
            • Owen L.
              • September 30, 1991
              • 863
              This is from a Sunoco page:
              There’s another advantage of higher-octane fuels: They’re more stable when it comes to storage. To explain the science behind that fact, we’re going to crib from a post on the Sunoco Race Fuels website by Technical Specialist Zachary Santner:
              “87-octane fuels tend to be less refined and contain more unstable hydrocarbons. As the months pass during storage, these unstable components react to form gums, varnishes and lower-octane hydrocarbons. As a result, the octane can decrease within months for 87-octane fuels, especially when stored under less-than-ideal conditions.
              “93-octane fuels are more refined and contain more stable hydrocarbons. These stable hydrocarbons can last two to three times longer than those in 87-octane fuel. Even with proper storage, 87-octane gas can start to degrade in three months; 93-octane fuel should last closer to 9 months before degradation is noticeable. Keep in mind that 93-octane fuels are still susceptible to octane loss and vapor pressure decreases due to butane evaporation.”
              • Tom D.
                • September 30, 1981
                • 2132
                Thanks Duke. I shared some of this with a few NCRS Michigan members. Still a bit cold here this Sunday. morning.
                https://MichiganNCRS.org
                Michigan Chapter
                Tom Dingman
                • Bill M.
                  • 1322
                  I worked on a 55 Chevy that had been sitting for years the entire fuel system had to be replaced. After this mess I would not leave fuel in the car when sitting for extended period more than 6 mos. When I think my car will be on blocks for more than the winter I completely drain the tank and drain the fuel lines. When ready I will fill tank and purge the lines before firing up the car
                  • Michael M.
                    • February 1, 1993
                    • 604
                    I highly recommend aviation fuel not only for it being more stable but for its octane.
                    • Paul H.
                      • September 30, 2000
                      • 679
                      There is an effort by some in Congress to move us to E15. I can only assume this will not be good for our old cars. Mine run fine on E10 93 Octane. Thoughts?
                        • 15660
                        I have not currently heard of such an effort. It has occurred in the past, but didn't go anywhere. I don't think the current congress and certainly the current executive administration would support such an effort, and I don't know of any manufacturers that would support it.
                        If anything they are more likely to eliminate the current ten percent ethanol mandate (just make it optional). There was such a move in the past in Congress, but the party that controlled congress and the then current administration didn't support it so it died.
                        https://www.forums.ncrs.org/forum/te...minate-ethanol
                        https://www.forums.ncrs.org/forum/te...thanol-mandate
                        https://www.corvetteforum.com/forums...l-mandate.html
                        There is ample evidence that ethanol does not reduce "greenhouse gas emissions", and is more expensive to produce per BTU than gasoline.
                        If such does occur again we all need to contact our elected representatives and objectively explain why E15 is not a good deal for the American people.
                        • Paul H.
                          • 679
                          Duke, US Senator Deb Fischer (R) Nebraska just reintroduced legislation seeking to convert to E15 nationwide. It's called the Consumer and Fuel Retailer Choice Act of 2025. She is joined by (D) Senator Tammy Duckworth and others. Whether it gets any widespread traction remains to be seen. It was also proposed in the House as well. I can only assume Fischer is trying to make the farmers in Nebraska happy. Doesn't make me happy though.
                          They were both on Fox News, 2 days ago touting the magical "benefits" of E15 and their proposal.
                          • Owen L.
                            • 863
                            E10 to E15 from the #2 and #3 corn-producing states, but I'm sure that has nothing to do with it.
                            I recall my vehicles "lost" about 10%-15% in gas mileage when E10 was put into place. How much more would E15 decrease miles per gallon?
                              • 11642
                              All you have to go is gas up in Iowa to find out...
