Quick question on 66 Trico Arm Covers - NCRS Discussion Boards
  • Larry E.
    • 1681
    Just want to make sure on this before trying. Can you install the above WITHOUT taking
    off the arm from the spline? Just do not want to scratch things in this tight area. Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1681
    Re: Quick question on 66 Trico Arm Covers
    ANYBODY?? Thanks/Larry Picture Below
    Larry
    • Stephen L.
      • May 31, 1984
      • 3158
      I don't know the difficulty of removing that cover from the arm. I'd suggest you don't try it with the arm on the car.
      Removing the arm: place a LOT of masking tape (4 or 5 layers) around the hole and area to minimize/eliminate the possibility of damage to the painted surfaces
      • Leif A.
        • August 31, 1997
        • 3633
        Don't even think about doing it on the car. The right tool for the job makes removal safe and easy.
        https://www.amazon.com/Lisle-65750-W...00CODS80&psc=1
        Leif
        • Larry E.
          • 1681
          Thanks to all for the response. I'll take the arm off to install the "Trico Cover" which
          came off in the operations test last weekend for the ILNCRS meet in Pontiac, IL.
          Did not even know it came off and luckily found it under the car when car was reloaded
          on the trailer. Thanks Again:Larry
          Larry
