If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I get the date is February 22 of I am guessing 1972. But is this an assembly line pump or a service pump. Thanks
Keith------
Very common small block, short-leg, external by-bass, waterpump used in PRODUCTION from 1964-68 on Corvettes requiring external bypass type pumps. Early examples have the top bypass tapped for 1/2" NPT and later are tapped for 3/4" NPT. This pump was also once widely used for GM SERVICE for all Chevrolet short leg applications after the internal bypass pumps were discontinued. It was then supplied with a plug to be installed for internal bypass applications. However, to my knowledge, it was never supplied with an adapter to convert the 3/4" NPT by-pass fitting to 1/2" for the very early applications originally using the 1/2" NPT fitting.
Joe it does have a capped bypass plug up top
[ATTACH=CONFIG]121781[/ATTACH]
so what your saying is it's a service pump made for all SB
Keith------
Given the 1972, 1982 or 1992 casting date, I would say it started life as a SERVICE waterpump. Short leg, external bypass waterpumps were not used in PRODUCTION after 1970 except for 1972-82 Corvette and some trucks which used a different short leg waterpump not to be confused with the earlier 3859326. These Corvette waterpumps, GM casting #330813, had a plug installed in the upper bypass fitting in PRODUCTION.
