69 fuel sending unit leaking...again - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Guys,
    I recently completed my 69 restoration which included new tank and fuel hardware. When initially installed, the fuel sending unit leaked. I searched the forum and believe I employed most of the tips to address this, like getting an OEM "cam", an OEM O-ring, pre-soaking the O-ring, and using the official sending unit wrench to tighten. This all seemed to fix the leak, but I only had a few gallons of gas in the tank all this time. I recently took the car to the gas station and filled the tank up and the sending unit started leaking again. What are my next steps??? Do I just not fill the tank up ever again??? Thanks for any tips.
    Mike
  • John S.
    • June 15, 2015
    • 508
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • Michael L.
      • December 15, 2006
      • 1416
      Re: 69 fuel sending unit leaking...again
      Thanks John I'll take a look at those.
      • Lawrence S.
        • April 1, 1993
        • 804
        I had the same problem on my 67 L79. I had to tighten the nuts on the bottom of sending unit that hold the threaded studs that go through the unit (replacing nothing) and that solved my problem.
