Big block shot peened half shafts
  • Joseph W.
    • February 20, 2022
    • 366
    I was looking at a set of half shafts this weekend that were for sale. Supposedly they were off a L89 car.
    The surface appeared to be textured, which I thought could be from a result of the shot peening.
    My buddy said it was rust pitting. The entire shafts had this consistent texture.
    Is the peening noticeable?
    Are there a difference in the flanges ( part that attaches to the half shaft) between a small block and BB?
    1971 coupe LS5 454/365hp
    1969 coupe L71 427/435hp
    1969 coupe L89 427/435hp
  • Mark F.
    • August 1, 1998
    • 1394
    Re: Big block shot peened half shafts
    Originally posted by Joseph Westbury (68953)
    I was looking at a set of half shafts this weekend that were for sale. Supposedly they were off a L89 car. The surface appeared to be textured, which I thought could be from a result of the shot peening. My buddy said it was rust pitting. The entire shafts had this consistent texture. Is the peening noticeable?...
    Yes - a peened surface should be uniform and "dimpled".
    Whether you have shot peen dimples compounded with rust pitting is another story...
    any pix available ?
    And here's probably more than you want to know about shot peening...
    https://superiorshotpeening.com/news...0the%20surface.
    thx,
    Mark
      • 43133
      Joseph----
      No difference between small block and big block half shaft flanges.
      • Joseph W.
        • February 20, 2022
        • 366
          • 43133
          • Donald H.
            • November 2, 2009
            • 2562
            Heree's a picture of a 72 LT1 half shaft. the LT1 shafts were also shot peened according to the judging guide. If you enlarge the picture you can see the texture which I believe was created by the shot peening.
            Don Harris
            Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
            • Joseph W.
              • February 20, 2022
              • 366
              At what point do they become unusable?
              Thank you Don for the picture.
              I can see the big difference between mine and Don's in terms of condition.
                • 43133
                Joseph------
                I think the ones you picture are probably still usable. If you can find some place to get them re-shotpeened that will remove the rust and give them a good surface, albeit slightly pitted from the rust. Otherwise, just have them bead or sand blasted.
                • Joseph W.
                  • February 20, 2022
                  • 366
                  Thanks Joe!
                  • Ron G.
                    • December 1, 1984
                    • 861
                    Joseph,
                    I have participated in many threads regarding this subject. Including the size of the shot peen, a good vendor on East Coast, and exactly what portion of the half shafts get shot peened.
                    - Ron
                    "SOLID LIFTERS MATTER"
