If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
For your 1963 there are 15 points total for the Originality column on the frame. If you count Finish as 20%, that’s 3 points.
You could paint it pink and theoretically lose no more than that.
You’re fine.
Thanks everyone. This was my 3rd attempt at it to match black & white pictures I have seen. Never going to match factory but as close as I can get it. Working with asphalt is just plain nasty so I will go with it as is. If I had to do it over again I would have just taken Patrick's advice and painted it pink. Barbie would have liked it.
