If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Mike, order the build sheet for your C-4 from the Corvette Museum. Give them your VIN and when you receive same all items your car came with will be noted.
