1963 "870" Cylinder Block Casting Number(s) Font... Correct???
  • James W.
    • December 1, 1990
    • 2612
    Do the casting number(s) font for this block look correct?
    • September 16, 2008
    • 6939
    Re: 1963 "870" Cylinder Block Casting Number(s) Font... Correct???
    IMG_2255.jpgJim here a pic of my 63 casting number, my car is a March built. Maybe theyhad a different castings.does the block have a square plug in front by the stamp pad? Tonawanda blocks used the date (63) flints use the number (3). Also
    Last edited by Edward J.; August 17, 2023, 11:43 AM. Reason: Added Tonawanda block date.
    • Kenneth B.
      • September 1, 1984
      • 2078
      Could have been a different pattern. Part # tags were screwed in a machined pocket & secured with 2 screws like the date tag. You could take all the paint off to see if someone machined in another tag which is not likely. They sure look like they are cast in & the real deal.
      • Harry S.
        • August 1, 2002
        • 5187
        James, please post a picture of the date casting.
        • James W.
          • December 1, 1990
          • 2612
          Casting number picture.
          • Harry S.
            • August 1, 2002
            • 5187
            I do not believe that is a Fling Block, probably Tonawanda.
              • 43133
              Harry------
              Yes, this is almost certainly a Tonawanda block and no such block was used for any 1963 Corvette.
              The lack of the pipe plug above the timing cover that Edward mentioned will confirm it.
              • James W.
                • December 1, 1990
                • 2612
