Dual Four Barrel Carburetor - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    I almost never use the second carburetor. Gas sets in it and turns in to a mess and clogs up all the jets. If if disconnect the gas line to the second carburetor will the car run well on one carb? Thanks Jimmy
    • 15706
    Re: Dual Four Barrel Carburetor
    You can try that (make sure you securely plug any open fuel lines) or find some freeway on ramps or roads where you can safely do some WOT runs through at least the first two gears.
    Back in the day we called it an "Italian tuneup".
    • Kent S.
      • February 1, 1993
      • 210
      Do you have the idle jets adjusted out 1 1/2 turns? The carb will burn gas even if you don't open up the carb. All that said - I agree with Duke don't be afraid to get into it occasionally - it's fun!
