1967 4 speed shift pattern - How do I know if I have a repro or original? - NCRS Discussion Boards
  • Brian E.
    • May 28, 2018
    • 288
    How can I determine (prior to a judging event) if this shifter pattern is original or a repro? On page 39 of the current 67 NCRS judging guide it states: "The shift pattern is de-bossed and silk screened in black on a small brushed aluminum plate..." What are the other attributes of an original shift pattern plate?
  • Gary B.
    • February 1, 1997
    • 7065
    • Leif A.
      • August 31, 1997
      • 3650
      Re: 1967 4 speed shift pattern - How do I know if I have a repro or original?
      Originally posted by Gary Beaupre (28818)
      Brian,
      If it’s a GM part, then I think it must be in a used part, since I think all the GM service replacement shifter patterns had the 4 tabs on the back.
      Gary
      Gary.
      For Corvette, 1963 was the only year that had the four tabs. Subsequent years were all "flat" backed. All original plaques were de-bossed...nobody, that I am aware of, is making a de-bossed plate...just silk screened.
      Leif
      • Gary B.
        • February 1, 1997
        • 7065
        Leif,
        Yup. I agree. No easy solution for a damaged plate as far as I know.
        Gary
        • Mike E.
          • February 28, 1975
          • 5141
          • Steve B.
            • March 1, 2002
            • 1191
            Brian, that looks original to my untrained eye. The replacements that I have seen have font/pattern that is either noticeably thinner or thicker than what you have.
            • Stephen L.
              • May 31, 1984
              • 3162
              For what its worth, here is a comparison I picked off the internet sometime ago.........
              • Brian E.
                • May 28, 2018
                • 288
                Does anyone else see that the original plate in the photo directly above has more of a gold-ish hue to it than the other 2 plates? Can anyone confirm this? Or is this hue more likely to be some kind of light reflection? Thanks.
                • Alan D.
                  • January 1, 2005
                  • 2053
                  Believe that is due to age!
                  • Brian E.
                    • May 28, 2018
                    • 288
                    Understood.
