1969 Brass/Copper Radiator Upper Hose - NCRS Discussion Boards
  • Steve M.
    • January 1, 2006
    • 256
    I have a 1969 L46 convertible (October 1969 Build) and wanted to check on the correct Upper Radiator Hose. I have attached 2 photos. One is installed on the car now and the other is available for use. Is either one correct ? If not can someone post a picture of an original hose with proper part numbers ? Thanks for any help.
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: 1969 Brass/Copper Radiator Upper Hose
    Steve,
    This is my late 69 L46 with copper radiator. You can see the part number on the hose.IMG_1323.jpg
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
    • Lawrence M.
      • February 1, 1995
      • 404
      Hi Steve, When I first viewed your post the pictures did not appear. After I made my post your pictures popped up. You have the correct number hose. The one with the white stripe has more of the alligator skin look like the originals had.
      Larry
      • Steve M.
        • January 1, 2006
        • 256
        Thanks for responding
        • Francais D.
          • October 8, 2016
          • 93
          I have the same set up and my hose has 368685 . I have the original lower hose and I thought I checked the # on the upper a couple years ago and thought that was good . What do I have , obviously not original
            • 43222
            Francais-------
            The original GM #3946852 was discontinued in July, 1980 and replaced by the GM #368685. The 368685 was used in PRODUCTION for early 1976 Corvettes. It has now been discontinued by GM.
            How the 3946852 and 368685 differ I do not know. However, the fact that the 368685 superceded the 3946852 indicates that it will SERVICE your application.
            • Francais D.
              • October 8, 2016
              • 93
              Thanks that explains it
              • James G.
                • August 22, 2018
                • 800
                Steve,
                The one you pictured with the white stripe under the part number installed on your car is exactly like the one on my 71 LT1 survivor.
                James A Groome
                1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
