1957 RPO 684 Eccentric Brake Anchors and special washers availability - NCRS Discussion Boards
  • John N.
    • January 31, 1975
    • 451
    Any source for the RPO 684 Eccentric Brake Anchors and special washers?
    Thanks!
  • Mike E.
    • February 28, 1975
    • 5115
    Re: 1957 RPO 684 Eccentric Brake Anchors and special washers availability
    John,
    Sent you a pm.
    Mike
    • Mike M.
      • May 31, 1974
      • 8344
      john: if the
      rev. can't help ya, i think KC strawmyre(the 65 team leader) may have what you need.his contact info on p2 of Restorer. mike
      • John N.
        • January 31, 1975
        • 451
        Mike
        Thanks! I needed them by Wednesday, and found a local machinist to make some.
        Not cheap!
        John
        • Patrick S.
          • December 31, 1987
          • 209
          A COUPLE OF YEARS AGO i DID A COMPARISON OF THE AFTERMARKET ECCENTRICS TO THE ORIGINAL GM PIECES. THE DIFFERENCE IS LARGE AND YOUR ABILITY TO ALIGN THE FRONT END IS REALLY LIMITED WITH THE REPO STUFF. I ACTUALLY WENT TO THE JUNK YARD AND SEARCHED / SCAVANGED SOME OEM PIECES THAT WERE NOT WORN TO USE.
          MAYBE HERE BUT MY PICTURES ARE GONE.
          • Jim L.
            • September 30, 1979
            • 1781
            I think you are describing the caster/camber eccentric. John is asking about a special brake shoe anchor pin which is made with an eccentric for centering the shoes within the brake drum.
