1963 BW T-!0 Shifter Base Contacting Bracket Bolt Shifting to 3rd Gear - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 475
    The base of the shifter is contacting/rubbing the bracket bolt head when shifting into third gear (BW T-10, 340HP). All other grear positions engage properly. There is what looks like a hole for a set screw at the base of the shifter but nothing in it. Is there a grommet or spacer that is missing to keep the shifter from hitting the bolt head? Photos attached.
    Thanks in advance.
    Fred
