If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I came across a C2 Oil canister and can not tell if it's original or not. I searched the archives for almost an hour looking for measurement on both, no luck
Anyway, anyone know the metal thickness of the original vs. a repro.
Somewhat of a coarse measurement for you Harry, but should be sufficient for your purpose. The original to the car can on my '60 has 3/32" (.09375)+ - thick walls. *I can't comment on the reproductions.
I have both original and repo. I am not home so i can't measure it. But i recall the repo is probably half the thickness of the original. the repo tend to leak.
Bruce, I agree. If I have an original I'll restore it. If I have a repro I'll recycle it. If you could measure yours that would be great. Thanks
Thank you Frank Dreano for sending the oil canister. I decided to take another approach instead of a push washer. I used a pipe cutter, the one plumbers use to cut copper pipe. I used the measurement I gatherer and cut a ring into the canister bolt, not too deep. I then took my Dremel and made the cut wider. Took a new crush washer for fit then installed a 1/2 retainer ring. As soon as I find the bell, spring, metal washer and rubber washer I'll put it back together.
Nicely done Harry!....
If decide to do mine, instead of using a Dremel I'll attempt
forming the ring using a drill press. (poor mans lathe)
Definitely would try first on an ordinary bolt though!
Looking forward to photos of the completed project.
Cheers
