If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
If you post a left side and a rear view picture of the shifter with the linkage levers straight down, I may be able to give a part # and application. I have a few vintage Hurst catalogs.
