'65 Clutch Cross Shaft finish
  • Gene T.
    • June 1, 1997
    • 78
    I have searched in TIMJG to find whether the clutch cross shaft should have semi-gloss or gloss black. Which should it be ?
    • 43133
    Re: '65 Clutch Cross Shaft finish
    Gene------
    Neither. The cross shaft was zinc plated or galvanized.
    • Gene T.
      • June 1, 1997
      • 78
      Thanks Joe for your info !
        • December 1, 2005
        • 167
        Gene,
        When restoring my '65 coupe (#5248, an early car), I found the clutch cross shaft to be galvanized. I was not expecting that. Kind of cool tho.
        • Ron G.
          • December 1, 1984
          • 861
          Joe,
          I could be wrong, but I believe that it was not galvanized. Although, I am really not sure of the original finish. It could be zinc, but zinc is usually brighter. Again, not sure, but I have one sitting in my basement, and I now am thinking of bringing it to my plater here in Connecticut. After I do, I will re-visit this thread again and report my findings.
          "SOLID LIFTERS MATTER"
            • 43133
            Originally posted by Ron Goduti (8076)
            Joe,
            Ron-------
            Hot dip galvanizing produces a somewhat "uneven" zinc finish. However, electro hot dip galvanizing produces a smooth finish virtually indistinguishable from electroplating. I'm fairly sure that the original cross shaft on my 1969 was either hot dip galvanized or electro hot dip galvanized Here is a photo of a portion of my shaft:
            I have NOS examples [none for sale] of all of the cross shafts used from 1963-1981. Here are some photos of the 3872962 (1965-66 big block) and the GM #3888279 (all 1967-81):
            3872962
            GM #3888279
            If galvanized or electro galvanized, the coating has to be zinc. If electroplated, it could be zinc or cadmium. However, I've tested the finish material and its ZINC.
            • Gene T.
              • June 1, 1997
              • 78
              Thanks Terry and Joe. I cleaned my cross shaft up with kerosene and then lightly polished with a piece of Emory cloth.
