1961 Corvette Wiper Motor - NCRS Discussion Boards
  • John W.
    Infrequent User
    • April 1, 2002
    • 5
    Sent my wiper motor off for repair. Question is, not sure how to hookup wiper motor to transmission cable when I get it back?
    John Westenhaver
    37760
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 1961 Corvette Wiper Motor
    The motor should come back with it set in the park position. Set the center hub on the car with the wiper blades set to the park position. Then just set the base of the motor into the center hub, and fasten the two screws wiper motor to base. (With the ground wire in place.). If Your transmissions and center hub are not connected, that is an additional issue. That needs to be done first.
    • John W.
      Infrequent User
      • April 1, 2002
      • 5
      Thanks Mike. Yes, that's really my issue is that the transmissions and center hub are not connected and manual doesn't seem to show that very clearly
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        John, In the Sticky threads above, Database of Restoration documents, there are 2 articles (Title-Wiper, C1) describing the details I believe you need, including how to connect the cables from the transmissions to the center drum.
        Direct links to those articles below.
        Rich
        https://www.forums.ncrs.org/attachme...0&d=1499166237
        https://www.forums.ncrs.org/attachme...0&d=1499168146
