If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Looking for a shop within driving distance that can repair the case on my 66 4 speed , the counter shaft in the case leaks and will need to be fixed if i decide to do PV . any help or info would be great
thanks Bob Peckham
thanks Bob Peckham
Bob-------
If you are not so-aware, I believe the transmission will need to be disassembled down to the bare case for the repair to be accomplished properly. In that case, the bare case can be easily shipped to a repair facility. I would contact Larry Fischer at D&L Transmissions for further information.
The best fix involves the installation of a bushing in the case. Fixes involving just the use of various sealants are problematic and, usually, short-lived.
Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
