Accessory Dates Codes - NCRS Discussion Boards
  • Paul A.
    • April 21, 2021
    • 227
    Regarding accessory dates, starter, alt, carb, radio etc. What is an acceptable 6 month prior rule to go by. Engine assembly date or car build date?
  • Allen N.
    • January 1, 2003
    • 288
    Re: Accessory Dates Codes
    I have always gone on car build date. There is usually only a couple weeks difference in the two dates, so most of the time a part's date will be within six months of both dates.
      • 15601
      Paul, welcome to the TDB.
      All the items you mention were installed at St Louis, so dates are relative to the body build date.
      Items installed at the engine plant (water pump, intake manifold, heads, etc.) are relative to the engine build date.
      You can tell items installed at St Louis by their part numbers being listed in the AIM (Assembly Instruction Manual).
      • Gary B.
        • February 1, 1997
        • 7024
        • Harry S.
          • July 31, 2002
          • 5309
          Terry, spot on!
          • David H.
            • June 30, 2001
            • 1532
            Paul
            Don't just start changing things on an original car. Has/has not your car been restored?
            There are reasons for some parts to be beyond that 6 month window. Do some research before changing a part.
            If you intend to have this car Flight judged, then become familiar with NCRS judging standards, Standard Deduction Guidelines, and our CDCIF matrix approach. Then you can assess cost of replacing a part vs potential points lost.
            That information is in NCRS Judging Reference Manual (link below).
            National Corvette Restorers Society! Judging Reference Manual - NEW Ninth Edition! The NCRS Judging System is quite complex- don't go in without a guide! This manual outlines all rules, procedures, and policies pertaining to NCRS judging events held world-wide, conducting an NCRS Judging School, Duntov Mark of Excellence Awards, McLellan Mark of Excellence Awards, Flight Awards, Performance Verification Testing,
            Dave
            • Paul A.
              • April 21, 2021
              • 227
              Thanks for all the informative posts and links. I did find the “engine and components as shipped” in the AIM. Any parts that I’m replacing are aftermarket parts. Carburetor, alternator, fan clutch…Few others. So I’m replacing with the correct part and correct date code. My Delco starter is a couples days after the engine assembly date, but before the body build date. However, I’ll just let it be.
              Dates as follows.
              Block cast date; A 19 6
              Engine assembly date; 02 08
              Car build date; 2/16/66
              Delco starter date; 6 B 11
                • 15601
                The starter was installed at ST Louis. That date is just fine.
                • Paul A.
                  • April 21, 2021
                  • 227
                  Thanks Terry
