Hello,
I have a 300 hp with a Carter. I'm having a hard time starting the car but when it starts, it runs great. The engine will crank for many seconds and then eventually, it will start.
I'm sure the carburetor hasn't been touched in years and the grime on it proves it. I've been told by a carburetor rebuilder that the gas in the bowl evaporates/boils out thus the need for the fuel pump to fill the bowls before it will start. The rebuilder said that since the car runs great after it starts, I don't need to rebuild the carburetor. I started the car today (after many cranks) and it ran well. A few hours later, while still in the garage, I had a hard time starting the car. But once it's started and then I shut it off, it will fire up right away! I've never had that issue before in my other cars. Another opinion is that the carburetor is leaking into the intake manifold and it needs to be rebuilt.
Any other thoughts about what's going on with this Carter?
Questions?
Questions?
