If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Here is a pic of a big block 67 Starter. Pink goes to the 'R' terminal on the solenoid (Outside) Orange/Black to the 'B' terminal Purple to the 'S' terminal (Inside next to Oil pan) 14 gauge black with larger lug goes to Starter Mounting Bolt for ground.Starter.jpeg
