Can someone tell me where the capacitor in the photo below should be attached? L36 with A/C and AM/FM. The C60 AIM drawing shows the purple wire going directly to the motor. Maybe there's another drawing I'm overlooking. The fork seems to be wider than necessary to fit under a motor flange screw. Also the "fingers" of the fork have tips that turn down as if to assist in gripping whatever surface it attaches to.
Edit: I forgot to ask in the original post - Because the purple and ground connections are the only two electrical connections to the motor, can I briefly connect 12vdc (+ to purple) just to see if the motor spins up? I just want to be sure the blower wheel wasn't jammed when the assembly was reinserted into the housing.
Mike
Mike
