What is wrong (If anything) on the following picture of the Parking Brake Pulley Area that I had in my
picture file.(1966 Corvette) Questions>
1. Looks like the Bolt that holds he pulley supposed to be reversed (A.I.M) Correct?
2. Pictures show (2) Rubber Caps(Boots) where the cable goes through. I know the top one is the
Correct one from GM as mine has this bigger cap. Not sure on the smaller one below it.
A.I.M. shows none. What is correct here??
3. The fastener that holds the cable to the pulley bracket is listed in the A.I.M. as a "screw"
(453007); the picture shows a "bolt". Which is correct?
4, Any other comments will be welcomed on this picture. Thanks In Advance > Larry
