Question On The 66 Corvette Steering Damper Shock/Hdwe. - NCRS Discussion Boards
  • Larry E.
    • 1695
    One project that is left to do before judging on my 66 Base Engine Coupe>No Power Steering is to install the above. Couple
    of basic questions on the Steering Damper Shock and Hdwe.
    1)Would the shock(AFAIK) part #Placell #3178100>GM #22011964(Discontinued) be identical for all C2's?
    2)Would all the Hdwe. to install the shock be identical for all C2's or are they any unique features
    for the 66 Corvette?
    3)Anything I should know when installing the above? I assume no adjustment in the the steering is required?
    Correct?
    Thanks in advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1695
    Re: Question On The 66 Corvette Steering Damper Shock/Hdwe.
    Maybe my old reliable adviser's>Harry Sadlock or Leif Anderson have some idea's on this? Of
    course anybody else is also welcomed. Thanks>Larry
    Larry
    • Harry S.
      • July 31, 2002
      • 5342
      That shock was used on all C2's
      1963 3178100 Shock Absorber 9 3.00
      800 Shock Absorber & Brackets
      1964 3178100 Shock Absorber
      3 9 800 Shock Absorber & Brackets
      1965 3178100 Shock Absorber Assembly
      3 9 19000 Shock Absorbers & Brackets
      1966 3178100 Shock Absorber
      A3 9 19000 Shock Absorber & Brackets
      1967 3178100 Shock Absorber Asm. (Steering Damper)
      A-3 9
      • Leif A.
        • August 31, 1997
        • 3650
        Well, Harry beat me to it with the correct information. There should be no need for any adjustment in your steering...install and drive on.
        Leif
