If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
When turning the upper control arm pivot pin to adjust the caster and camber with a bubble type gauge does the car have to be sitting with all the weight on the wheels? Should the 1/4 inch allen wrench turn easily? Seems like it would be easier with the tire off, or does this mess up the reading. Thanks.
