If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Hi All, Sorry for the basic question but I can't seem to find it written anywhere or able to locate and picture. What direction do the seat belt tags in a 1963 face? Are they on the top of the belt or the bottom?
The attached photos show both sides of each belt in the set. The label at the tongue end of the tongue belt and the label at the anchor bracket of the buckle belt and how they are oriented. Note these have the late 63 stitching. Hope this covers it.
You may want to take note that the thread used to attach the tag to the seatbelt is two colors. White thread is used on the surface of the tag and a color matching the seatbelt material is used on the back side.
