What type of gun works on these rivets?
C3 splash shield mounting rivets
Re: C3 splash shield mounting rivets
No type of gun sets those.
If not mistaken it requires an air hammer and bucking bar.James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
They are made of soft aluminum and as noted above you can use an air hammer with a bucking bar. The aluminum is so soft that you can also use a hammer and back up the rivets with some type of steel plate.- Top
If that rivet is the one you plan on using for splash shield installation you might want to double check if correct type. Per UPC 1 sheet D9 rivet #9409244 is a #100 countersunk head aluminum rivet 3/16 X 7/16 pointed head.- Top
FWIW I set some 1/4" dia STEEL rivets yesterday for a bracket on a bumper, it took more time to get out the tools and set up for the job than it did to set the 2 rivets.James A Groome
