3rd belt, water pump tp crank - NCRS Discussion Boards
  • David H.
    Infrequent User
    • November 18, 2017
    • 5
    A white '65 SB lost a point today for a missing 3rd belt water pump to crank., 250 or 300 engine. No way to adjust or install a belt without an idler. If this car came without an idler pully should he have lost a point?
  • Terry D.
    • May 31, 1987
    • 2698
    Re: 3rd belt, water pump tp crank
    I would think he would have to prove the car came without the pully
    • Jim D.
      • 2885
      The 250 hp and 300 hp engines did not come with an idler assembly.
      • Kenneth B.
        • August 31, 1984
        • 2091
        Believe all engines came with the Jesus belt with no adjustment. You need the correct diameter belt
        • Jim D.
          • 2885
          The base and 300 hp engines only had one belt. The rest of the SB's had 2 with an idler assembly. Only the big block had the "Jesus" belt. I came up with way more descriptive words when installing it.
            • 43287
            All------
            1965 250 and 300 hp small blocks were originally equipped with balancer pulley GM #3744043 and waterpump pulley GM #3790356. Both of these pulleys are 2 groove pulleys. One groove was, of course, used to drive the alternator. For cars without C-60 and/or N-40, the other groove had to be either unused or used for a captive belt. I don't know which.
            I concur that no 250 or 300 hp was equipped with an idler pulley.
            • Chris D.
              • November 1, 2002
              • 198
              Simple answer is that while 63-65 250 and 300 hp had two groove pulleys on the crank and water pump, if no A/C or P/S, they only came equipped with a single belt. AIM shows only a single belt. Parts catalog look up yields only one belt. Pics in Corvette Restoration vol.2 confirm. The unused pulley groove does look incomplete but I'm convinced the came that way.
              • Mark E.
                • April 1, 1993
                • 4609
                After all these years, you would think you midyear guys would have already figured out which belts to use.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Kenneth B.
                  • August 31, 1984
                  • 2091
                  I agree its NO fun at all. Bloody hands & pinched fingers. LOL
