69 Dimmer Switch - NCRS Discussion Boards
69 Dimmer Switch
  • Philip A.
    • September 18, 2021
    • 94
    69 Dimmer Switch
    Was 69 a year they changed the dimmer switch to be under the carpet?
    My 69 has a plastic pedal that is riveted to the body and that rides on top of the Dimmer switch and the carpet goes over it , no grommet as it is hidden. Is this correct?
    TIA
    • 15631
    Re: 69 Dimmer Switch
    Mine has a plastic pedal (which is cracked but no one shows a replacement )that is riveted to the body and that rides on top of the Dimmer switch and the carpet goes over it , no grommet as it is hidden. Is this correct?
    TIA
    Yes, that's the way it is. My 1970 is the same.
    • David M.
      • September 30, 2004
      • 533
      April built 68 has the paddle under the carpet.
      Im going to move the brights up to a switch under the dash or somewhere creative. Each and every time I clutch I simultaneously turn on the brights, Most aggravating.
