40083 Fuel Pump info needed - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2925
  • Mike M.
    • May 31, 1974
    • 8389
    Re: 40083 Fuel Pump info needed
    dave: i believe the screws retaining either bottom plates are S logo'd and natural or black phos. all 3 of our 65 FI 40083 pumps are configured as such, and one of the 65 FI vets has been ours since 1970, with just over original 20K miles. regards, mike mccagh
    • Dave S.
      • August 31, 1992
      • 2925
      • Mike M.
        • May 31, 1974
        • 8389
        main body to top also phillister with S and natural vs black phos. i dont recall seeing any lock washers on the 4 that hold the bottom plate to main body. mike mccagh
        • Gary B.
          • February 1, 1997
          • 7024
          • Dave S.
            • August 31, 1992
            • 2925
            • Gary B.
              • February 1, 1997
              • 7024
              • Alan D.
                • January 1, 2005
                • 2039
                Dave,
                Have two pumps, 1 original from my 64FI and 2 is dated 1965. The second was purchased in 1967 from GM thinking I had a fuel pump problem, it was the TI. Both of these have black screws, integral washers, and S logo. Also kept the lower diaphragm with the yellow markings.
                • Dave S.
                  • August 31, 1992
                  • 2925
                  Originally posted by Alan Drake (43261)
                  Dave,
                  Alan,
                  Does your original 64 pump have the cast bottom? Does the 65 service pump have a stamped dichromate bottom?
                  • Alan D.
                    • January 1, 2005
                    • 2039
                    Both are stamped bottoms.
                    • Gary B.
                      • February 1, 1997
                      • 7024
                      • Dave S.
                        • August 31, 1992
                        • 2925
                        • Gary B.
                          • February 1, 1997
                          • 7024
                          • Dave S.
                            • August 31, 1992
                            • 2925
                            • Mike M.
                              • May 31, 1974
                              • 8389
                              I believe that the 40083's installed on '64 solid lifter 327's had the die cast cover. sometime in '65, the stamped steel bottom cover showed up. mike mccagh
