'67 Spare tire tub and lid, painted or not? - NCRS Discussion Boards
  • Garry B.
    • January 1, 1991
    • 667
    Looking at the 6th Edition JG, under Spare Tire and Bolts page 90 it says, "the spare tire carrier is also constructed of unpainted natural dark gray fiberglass with visible strands in the finish and has a raised logo near the rear of the V brace with "MFG".... Next sentence says, "The carrier is painted semi-gloss black and held in place by the V-shaped reinforcement tracking......
    Should the entire outer surface be painted on both parts? Is the paint only on the tub part and not the lid? OR should there be any paint at all? Very confusing description at least to me. What should be what?
    Also, any chance that there would be some factory overspray of the undercoating on the sides of the tub portion? Thanks.
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
  • Leif A.
    • August 31, 1997
    • 3654
    Re: '67 Spare tire tub and lid, painted or not?
    That sentence (if quoted correctly) should read "The carrier/BRACE is painted semi-gloss black and held in place by the V-shaped reinforcement bracing assembly that is constructed of two steel angle bars that are welded to the stamped latch. It is riveted to the spare tire carrier with 3 flat head aluminum 3/16" diameter rivets on each bar"..rivets remain unpainted.
    Only the V-shaped carrier brace is painted semi-gloss black.
    Leif
    • Garry B.
      • January 1, 1991
      • 667
      Leif, I always thought that the whole this was kept natural fiberglass. In fact I was just stripping off the black that a previous owner has put on it when I decided to check the manual. I guess this is one of the reasons there is a 7th edition. Here is the actual page.
      Garry Barnes #18531
      • Leif A.
        • August 31, 1997
        • 3654
        Garry,
        The fiberglass carrier and lid ARE natural fiberglass. Only the V-brace, angle iron is painted. And, the rivets holding the V-brace to the fiberglass carrier are unpainted.
        Leif
        • Mike D.
          • July 31, 1996
          • 311
          Having judged Leif's car twice, he is correct, and we don't typically see overspray on the tub and carrier.
          Mike Doty
          Intermountain Chapter Judging Chairman
          Region VIII Director
          • Gerard F.
            • June 30, 2004
            • 3806
            Gary,
            The tub and lid are not painted, take a look at the stamps on my 67:
            Tub stamp position and stamp:
            Tub lid position and stamp:
            These are on a late June 67 22049
            Jerry Fuccillo
            • Garry B.
              • January 1, 1991
              • 667
              Thanks Jerry. Mine has a May 2, 1967 inside it. The interior of my tub is fine and original, but somebody before me decided that the entire outer tub and lid should be painted black. I have the lid done and working on paint stripper coat #3 on the tub. I use a very mild citrus based stripper and it works, it just takes time. It's all coming off and looking good.
              Garry Barnes #18531
              • Danny P.
                • June 30, 2002
                • 344
                V bar is Semi gloss the rivets are install with head on inside cover and rough press on the outside and also make sure tub lid show the part number and there is a little blackout on side of tub from blackout spray on top of mufflers on the line . 53 Original Spare Tire carrier.jpg54 Orignal spare tire part number 19146.jpgattachment (2).jpg
                • Garry B.
                  • January 1, 1991
                  • 667
                  Thanks Danny.
                  Garry Barnes #18531
                  • Leif A.
                    • August 31, 1997
                    • 3654
                    Garry,
                    Not that you need any more pictures, but I had these and thought I would post them up. I think you have everything you need.
                    Leif
                    • Garry B.
                      • January 1, 1991
                      • 667
                      Thanks Leif. Did you put a coating on the tub? It looks very shiny.
                      Garry Barnes #18531
                      • Leif A.
                        • August 31, 1997
                        • 3654
                        I did not. I'm pretty anal about cleaning. The entire chassis gets a complete detail twice a year during oil service because I do drive her quite a bit (6000 miles per year).
                        Leif
                        • Mark F.
                          • July 31, 1998
                          • 1609
                          Leif,
                          You are my Hero and you are the Man!
                          Wish I drove mine like you drive yours!
                          thx,
                          Mark
                          • Leif A.
                            • August 31, 1997
                            • 3654
                            Originally posted by Mark Francis (30800)
                            Leif,
                            Thank you Mark. Living in Texas affords year round driving and I certainly take advantage of it.
                            Leif
